2003 Toyota Matrix – leaking fitting and broken clip
I have a 2003 Toyota Matrix that’s leaking from a fitting (photo attached). I’ve been searching for a replacement but can’t find it on Toyota’s parts site. Anyone know the part number?
Also, I was trying to remove the connector on the right and ended up breaking the clip. Any idea where I can get a replacement? Everything else looks fine.
That looks like an aftermarket hose and clamp. When you say ‘fitting,’ do you mean the port where the hose connects to the nipple on the fuel pump assembly lid?
If the port itself is fine, the issue is probably just the hose and clamp. Best to use a fuel injection clamp—NAPA carries them, and you can find them online too. My guess is the hose you have is a little too big on the inside diameter. You’ll want a fuel hose that fits properly.
