As the title says, I changed my oil using 0W-20, like I’ve done plenty of times before. After starting it up and trying to drive around the block, everything went haywire. A bunch of warning lights came on, including the oil temp, ABS, and traction control lights. The car feels off, like it’s struggling to drive, but I don’t hear any weird noises from the engine.
Caiden said: @LyamGenesis
Oh no… I think I drained the transmission fluid instead. Am I totally screwed? I only drove it briefly around the block afterward.
You might be okay since you didn’t drive it much, but you’ll need to get it towed to the dealer or a mechanic and have the transmission fluid replaced ASAP.
My brother-in-law did the same thing on a Forester, and they sorted it out. Also, double-check that your oil isn’t overfilled now. Good luck!
Do you think I could fix it myself, or is it better to leave it to the dealer?
You can technically do it yourself, but it’s a tricky process. For reference, this guide explains how to do it for a Forester XT. There’s also a relearn procedure involved.
If you’re not comfortable doing it yourself, a transmission shop could be a good alternative to the dealer.
For context, we had the CVT fluid changed on our Ascent at the dealer, and it cost about $290.
Draining the transmission instead of the oil happens more often than you’d think. It’s a common post on this forum, so you’re not alone! Hopefully, it’s an easy fix.
