Drue
May 9, 2025, 6:15pm
1
Hey all, I’ve got a set of early 2000s Rays Gramlights 57C wheels. They’ve been cleaned up and rebalanced, and I’ve had them on my Subaru BRZ.
Thinking about switching to a 2014 Outback, and I’m not sure if these wheels can handle the extra weight.
They’re 17" and 5x100. I haven’t found anything clear about their load rating.
I would appreciate any help from someone who knows more about this stuff.
Asher
May 9, 2025, 6:15pm
2
They won’t fit. I’m pretty sure the Outback uses a different bolt pattern.
Vic
May 9, 2025, 6:15pm
3
Nah, they’re 5x100 — they should bolt right up. The only thing you might need to check is the offset.
Drue
May 9, 2025, 6:15pm
4
@Vic
Thing is, I’ve seen both numbers listed online — some say 5x100, others 5x114. I’m looking at a 4th gen Outback.
Tavi
May 9, 2025, 6:15pm
5
Drue said :
@Vic
You should look at this page: Subaru Outback - Specs of rims, tires, PCD, offset for each year and generation | Wheel-Size.com
@Tavi
Wait a second… did they change the bolt pattern right between 2013 and 2014?
Torrin said :
@Tavi
Nah, that site shows production years. Outbacks from 2010 to 2014 all use 5x100. It switches to 5x114.3 in 2015. So your wheels will go on fine — just double-check your tire size.
Sloan
May 9, 2025, 6:15pm
8
What about the other 5 holes around the hub? Are those just for looks or something?
Quin
May 9, 2025, 6:15pm
9
Those holes go through the wheel but they’re just to save some weight — not for mounting.
Asher
May 9, 2025, 6:15pm
10
Oh, I didn’t realize those were multi-pattern wheels.
Sloan
May 9, 2025, 6:15pm
11
@Asher
Yeah I’ve seen both types — some have actual dual bolt patterns, others just have holes that don’t line up for anything.
