I’m considering buying a 2010-2012 Toyota Rav4, preferably with the V6, for a 10,000-mile road trip. The trip will include some long driving days, dirt roads, and plenty of cargo.
I’ve heard Toyotas are reliable, but I’m wondering if this specific model and year can handle such intensive use. I plan to meticulously maintain it and replace any parts preemptively before the trip. Am I being overly optimistic, or is this a solid choice for such a journey?
Niall said:
The Rav4 is generally reliable, but for a used vehicle, reliability depends heavily on its maintenance history. Make sure to get a pre-purchase inspection (PPI) from a trusted mechanic.
Thanks, I’ll definitely look for a detailed service record and consider a PPI before purchasing.
I’ve had my 2009 Rav4 V6 since new. It’s at 185,000 miles now and has had zero problems, just routine maintenance. A used Rav4, if well-maintained, should handle your trip without issue.
The V6 in the Rav4 (2GR-FE) is an incredible engine. It’s known for its reliability and performance. As long as it’s been maintained, you’ll be good to go.
I have a 2010 Rav4 V6 with 250,000 miles. Aside from routine maintenance, I had some minor issues like a wheel bearing and alternator. Keep up with oil changes to avoid engine sludge.
The 2010-2012 Rav4 V6 is a solid choice. They’re reliable, but check for rust and ensure any needed maintenance is up to date. Spark plug replacement can be tricky but isn’t a dealbreaker.
Great choice, but have it inspected. Look out for common issues like leaking rear diff seals or VVTI gear rattle on cold starts. These are fixable but worth knowing about before buying.
While reliable, SUVs like the Rav4 might not be the most comfortable for long road trips. Consider a larger car like an Avalon if comfort is a priority.
