Can I add remote start to a 2022 RAV4 XLE?
I bought a 2022 RAV4 XLE in June, and I’m considering adding a remote start system. I live in a snowy state, and this would be a great feature for my wife. Is it possible to add remote start? Where should I look for installation options?
It’s possible your car already has it, depending on the features. Try pressing the lock button on your remote three times, holding the third press. If it doesn’t work, visit your dealer’s service department to have one installed. Many options integrate with the existing remote, and using a dealer ensures no warranty issues.
@Ode
Thanks! I tried the three-press method on my '24 RAV4 XLE, and it worked. You have to hold the third press after a slight pause.
Check if your RAV4 has the Audio Plus package (glossy black bezel around the screen). If not, you’ll need an aftermarket option. Avoid large chains like Best Buy; find a reputable local car audio shop for better service and expertise.
I installed Drone Mobile, which enables remote start through the factory key fob and adds app functionality for starting/locking from anywhere. It’s more affordable than dealer quotes. Look for a reliable auto sound/security business in your area.
I recommend N2 Designs remote start. It’s plug-and-play and works like OEM (three lock button presses). I installed it on my RAV4 and 4Runner with no issues. No need to cut wires, and installation is straightforward.
@beky
How easy is the N2 Designs installation? I was considering Best Buy, but they messed up my appointment, so I might do it myself.
Jody said:
@beky
It’s pretty simple. Taking apart the dash is the longest part, but it’s plug-and-play. If you’re careful, it’s straightforward. For hybrids, there’s one wire to tap; gas-only models are completely plug-and-play.
Yes, I added one for about $200. It integrates into the key fob.
Your RAV4 might already have it. Try pressing the lock button three times, holding the third press until the lights flash and the engine starts.
If you have the tech package, remote start may already be available through the Toyota app. If not, aftermarket systems are your best bet.
The Toyota app might support remote start. Check your infotainment package to confirm.
