Check Engine Light Keeps Coming Back… Any Ideas?
So here’s what’s going on: My check engine light keeps coming on and off. When I reset the ECU, it clears for a while, but after a few days, it comes back. I’m also getting warnings about the emission control system and hill-start assist not working.
I’ve already tried the basics, like tightening the gas cap and resetting the ECU, but no luck. The car drives fine otherwise.
I took it to a Subaru service center. They replaced the O2 and AFR sensors, ran diagnostics, and handed me a big bill. But within two minutes of leaving, the check engine light came back on.
I feel like if I go back, they’ll just replace more parts and charge me again. Any advice on what to check or do next?
Details: 2016 XT 2.0. Error code is P0172: “System Too Rich, Bank 1.”
Did you get the exact code?
Yeah, it’s P0172: “System Too Rich, Bank 1.”
Did they check the mass air flow (MAF) sensor before replacing the AFR sensor? Have you done any repairs recently?
@LisaMoore
No recent repairs. They didn’t mention the MAF sensor. Honestly, I wouldn’t be surprised if that’s the next thing they try to sell me.
Zan said:
@LisaMoore
Are you noticing any driving issues? Smelling fuel or anything unusual?
@LisaMoore
Nope, nothing unusual. No fuel smells, and the car drives fine. When it’s cold, the idle is high, but I think that’s normal.
@LisaMoore
When’s the last time you changed the air filter? Also, did you check for vacuum leaks?
LisaMoore said:
@LisaMoore
Changed the air filter 7 or 8 months ago. Haven’t checked for vacuum leaks yet but started watching YouTube videos to figure it out.
Is it P0420 by any chance?
No, it’s P0172: “System Too Rich, Bank 1.”
Got it. A lot of people replace the AFR and O2 sensors for this code, especially on the 2.5 engines.
Any chance you’re near Sacramento? We could take a look: link.
@Audrey
Mine’s the 2.0, and I’m way up in Northern Canada.
Zan said:
@Audrey
Gotcha. I’m surprised they replaced the AFR sensor instead of checking the MAF first.
For the 2.0, it could also be a high-pressure fuel pump leaking gas into the crankcase. Or maybe even leaking injectors.
