Hi, I took my 2024 Toyota to the dealer to check on a rough squeaking sound coming from the brakes. They found some rust or material on the brake rotors and suggested resurfacing them, with the cost on me. I have a few questions:
Is it normal for a car with only 12,000 miles to need rotor resurfacing?
Should I consider replacing them instead?
Since the car is fairly new, should the dealer cover the cost?
Not really. Rust can happen if a car sits for a while in damp conditions, but usually, just driving and braking cleans it off. Has your car been parked for long periods?
There’s a TSB (Technical Service Bulletin) for brake issues on some Toyotas. You could ask about TSB -0043-24, but it might only apply to Tundras and Sequoias.
Had a similar issue on a 2021 Yaris with 21k miles. The dealer told me the grooves and rust were normal, especially for hybrids. It still makes a bit of noise, but I was reassured it’s okay.
I used to work at a dealership, and we’d sometimes have to clean up rotors if a car sat for too long. I’d suggest driving more to see if it clears up. Sometimes debris can cause noise without needing resurfacing.
If it’s a hybrid, an easy fix is to drive in a safe area, put it in neutral, and brake to a stop a few times. That uses the brakes directly and should clear rust.
Resurfacing makes the rotor surface even, but it’s usually done when there’s more wear than 12k miles would cause. A little rust can be cleared just by braking normally.
