Check your coolant level first. Then pull the error codes to see what’s causing the issue. AutoZone or Pep Boys can scan it for free.
It’s showing code P26CB.
That usually points to the electric water pump. You might want to get it checked by a mechanic just to be sure.
Coolant level is full.
That code means the coolant pump is stuck. If your temperature gauge is running hot, you might have some overheating damage. Hopefully, it’s just the pump and nothing more serious.
If your coolant is fine, it’s probably the electric water pump. You may need to replace it.
What year is your car?
2018 XLE.
2018 XLE.
Can someone explain what the water pump does? I’m having the same issue and need help.
Kenan said:
2018 XLE.
Was your problem actually the water pump?
Kenan said:
2018 XLE.
Hey, did you get this fixed? I’m dealing with the same issue right now.
@WilliamMia
I had mine replaced at the dealer. Cost about $1,000 including parts and labor.
AuroraGleam said:
@WilliamMia
Was your check engine light on? Also, was your AC acting weird, like not blowing hot air?
2018 XLE.
Hey, did you ever figure it out? I’m dealing with the same thing now.
