I am seeking feedback from anyone with a 4th gen vehicle who also needs a front license plate, like I will.
I recently noticed some bumper plugs that a new owner found in his glove box. These plugs had been removed to mount his front plate, suggesting we might be able to mount a front plate without drilling holes in our new bumpers.
If you have dealt with this, please share your experience! Bonus points for pictures.
You can usually use those bumper plugs to mount your front plate without drilling. Check if your Tacoma has pre-drilled holes or plugs for easy attachment.
If you have a 4th gen vehicle and need to mount a front license plate, you might be pleased to know that many owners have successfully used bumper plugs for this purpose. These plugs are often designed to fill pre-drilled holes in the bumper, allowing you to attach a front plate without the need for additional drilling, which can help maintain the vehicle’s aesthetic and resale value. Some owners have found that using a bracket specifically designed to work with these plugs can provide a secure mount. If you’ve gone through this process, sharing your experience, including any tips on installation or specific brackets that worked well, would be greatly appreciated! Pictures of the setup would definitely help others visualize the solution as well.
