I was driving and hit a deer. Here’s a photo of the damage:
I’m not sure what steps to take next. Any advice?
The damage doesn’t seem too severe. The main thing is that you’re okay. Did you report the accident to the police? It’s good to inform your insurance agent as well. Then, look for a reliable body shop or see if your insurer has any recommendations. If there are no leaks and the car drives straight, alignment might not be a big concern. Hopefully, your policy includes rental coverage. Things should work out fine.
Is there any fluid leaking? When you let go of the steering wheel while driving, does the car stay straight or veer to one side?
Check the radiator and hose clamps just to be safe. This is one of the least damaging deer collisions I’ve seen. Consider yourself fortunate.
Honestly, you seem to have gotten off lightly. I’ve had deer collisions in work vehicles that caused major damage—new bumper, headlight, fluid containers, front driver’s side fender and door, and more. Be thankful it’s mostly cosmetic this time.
Glad everyone is okay. The damage appears mostly cosmetic, but debris from the front grill might have hit the AC condenser or radiator. It’s wise to have those checked. Also, consider inspecting the frame, though it’s unlikely the subframe is bent. Getting an alignment isn’t a bad idea, but not urgent unless there’s structural damage. Prioritize checking the AC and cooling system, then address the cosmetic repairs.
Consider salvaging the meat if the deer didn’t survive.
I doubt the deer was killed. Also, it seems the person who posted this didn’t file a police report, given the minimal road and vehicle damage.
Get a repair estimate from a trusted shop. If the cost is more than you’re willing to pay out of pocket, contact your insurance agent to check your comprehensive deductible and decide if filing a claim makes sense. For instance, if repairs are $750 and your deductible is $500, insurance would cover $250.
@Cort
Agreed. With insurance rates rising, it might be better to pay out of pocket if the repair cost is close to your deductible, commonly around $500. Also, the grill is from the first year of the next generation model; finding a replacement in a parts yard might be challenging.
If it were my 2025 Subaru, I’d check for any debris in the engine bay, inspect the frame for visible issues, get an alignment, and then fix the grill—in that order. Repairs should be under $800. Don’t forget to check pick-a-part yards; you might find a grill for around $50, which is much cheaper than buying new. Good luck!
Time for a barbecue?
Pay your deductible.
