How would you fix this flap that’s hanging?
You can either find the factory clips or screws, go with aftermarket ones, or just use zip ties.
Zip ties. Simple and effective.
If you want OEM-style retaining clips, check RockAuto. If you need a whole new splash shield, CarParts has them. Also, plastic trim remover tools make it easier to install new clips.
Whatever is holding up the driver’s side, use that for the other side. Or just go with zip ties like V mentioned.
Had the same issue—zip ties worked perfectly.
