Installed Apple CarPlay on my 2018 Prius, easy setup and it works
Looks great, how is the screen quality?
Can you still adjust the volume using the steering wheel buttons?
Yes, everything still works the same.
Some units need an extra adapter for that. Crutchfield is a good site to check for compatibility details.
Thinking about adding CarPlay to mine, which installation video did you follow?
Hard to believe Toyota waited so long to include CarPlay. Even 2018 models should have had it from the start.
Nice upgrade, enjoy!
I found a YouTube tutorial on how to add CarPlay to a 2018 Prius. The install was pretty simple. Took off the trim, plugged in the unit, and it worked right away. The screen is a bit blurry, but I think that’s just the Prius display. CarPlay itself is responsive.
@Nyle
If you’re sharing an Amazon link, you need to mention if it’s an affiliate link.
The auto-generated consumer links look different from amzn.to links.
Merrill said:
@Nyle
By the way, the second and third photos aren’t even of a Prius.
I own a Prius Prime, and I can tell right away.
@Nyle
Can you share the YouTube video you used? Would love to check it out.
Not a fan of how that looks, seems like it cheapens the car.
