Manual transmission leaking... any way to fix without a big job?
Noticed my manual transmission is leaking… hoping it’s not a huge fix, but I have a bad feeling. Anyone know if there’s a way to stop the leak without separating the case?
That’s the transmission case leaking. Unfortunately, it’s a big job. The case will need to be separated. I’ll check my FSM later and DM you some details.
Damn, that’s what I figured, but was hoping for an easier fix. Appreciate the help.
If you bought a used transmission, they usually guarantee it works and doesn’t leak. Might be worth calling the shop to see if they’ll swap it out if it’s under warranty.
