Pulled the trigger on some pizza cutters…
Wasn’t sure at first, but glad I went for it. They ride smooth on the road and handle well when aired down off-road. Just need the wife to sign off now.
Toyo Open Country A/T
What size are you running?
255/80/17
I’m a fan of tall skinnies too—running 255/75s now. Gonna bump up to your size once I swap my front suspension in about 40k.
I was looking at the 255/75/17s since my current tires are shot.
My only worry is getting wheels with the right offset. What wheels are you using with that size?
@Baylen
Stock SR5 wheels from the 2025 work great. Factory tires are already about 9.5” wide. I’ve also used them on 4th gen stock wheels. That size fits rims from 6.5” to 9” wide, so you’ve got options. Pretty sure the stock wheels are 7 or 7.5 wide.
@Amar
I thought you’d need a wheel with more negative offset.
I’ve got KMC-XD Rockstar 2s—hate them, they came with the truck. Would take literally anything else instead.
It’s a 2013 Trail with a 3-inch lift if that matters.
I’ve got a set too. Love how they look and they’re great on the highway.
Did you level it? Any rubbing?
Rocking 255/75/17s myself and I’m happy with them :man_shrugging:
Same here. Thought I’d see better MPG but oh well.
Mine’s slightly better, but nothing crazy.
I was thinking about those for my next set—need to replace mine ASAP.
What wheels are you using with that size? Offset is my biggest concern.
@Baylen
Still using the stock wheels. The size difference isn’t big enough to need different wheels or suspension mods.
Westley said:
@Baylen
I figured you’d need something with a lower offset.
I’ve got these awful KMC-XD Rockstar 2s that came with my truck. Really want to get rid of them.
I’ve got a 3-inch lift too, if that makes a difference.
@Baylen
