I want one but I live in the Netherlands
They’ve had these cars in California for a long time. I used to work at a Toyota dealership and saw some interesting folks checking them out at Roseville Toyota near the big hydrogen tank.
@Huang
Are they reliable and built to last?
AuroraGleam said:
@Huang
Honestly, I haven’t seen many on the road. They tend to leak fluid out the exhaust.
AuroraGleam said:
@Huang
Yep. That’s just water coming out.
@CharlotteMia
I guess their comment was meant to be funny, but in reality, all traditional engines also produce water in their exhaust. It’s part of how things work. https://lubricants.repsol.com/en/support/nuevas-faqs-ii/es-normal-la-salida-de-agua-por-el-tubo-de-escape-de-un-vehiculo/
@Broderick
I assumed it was mostly water. But there could be oils and chemicals from coolant too. Drinking that “water” doesn’t sound safe.
Huang said:
@Broderick
Doubtful. Modern engines don’t burn oil or coolant noticeably over long distances, so there shouldn’t be much in the exhaust.
@Lucy
What? There are plenty of cars on the market that burn oil… just look at VW and KIA.
SharonCarter said:
@Lucy
This comment is empty, admin should fix
Huang said:
@Broderick
It’s definitely just water.
Huang said:
@Broderick
Then drink it if you’re so confident.
@Huang
Don’t challenge me like that
Huang said:
@Broderick
Hydrogen burns clean, only produces water.
Hydrogen burns clean, it’s just water
That’s been clear to me, which is why I took their joke comment lightly.
Hydrogen cars create energy by combining hydrogen with oxygen to generate electricity, which then powers the car. There’s no traditional combustion involved.
@Broderick
Charging lead acid batteries can also produce hydrogen, but it’s not in useful amounts. You need to keep sparks away during charging.
Creates energy and water as a byproduct
That’s not the way it works. They combine hydrogen with oxygen, creating electricity in the process, which drives the electric motor. No combustion here.
AuroraGleam said:
@Huang
Water…
AuroraGleam said:
@Huang
I doubt you’ll find one older than 15 years because of hydrogen embrittlement.
