Let’s get the wheel setups rolling—drop your current setup or what you’re planning!
@vanice
Liking those SCS wheels—are they -38 offset? I’ve been thinking about going -38 myself.
Beryl said:
@vanice
@vanice
What size tires are you running? I’m on 295 Toyo RT Trails at the moment.
Beryl said:
@vanice
Running 34s—285/75/17 Falken Wildpeaks.
Beryl said:
@vanice
-38s it is for Black Friday then!!
@vanice
Gonna have to redo my BMC and clean up the pinch welds again if I go that route. Might go with RRW -38s.
Beryl said:
@vanice
Yeah I had to trim quite a bit. I rub at full lock on the back fender wall, even had to ditch the rocker panel caps
It’s fine on pavement, but once you air down for trails, it gets tight.
Just ordered a set of Method 703s!
Planning to mount some MT Baja Boss A/Ts in 285s. Running 2" up front with Bilstein 6112s right now, but bumping to 2.5" when I get the tires on. Also have Accutune UCAs going in. Gonna knock it all out in one go in a few weeks.
@Swift
Nice! Can’t wait to see the final setup!
