Where is the AUX jack in a 2021 Camry XSE?
I know I could check the manual, but the people here are way more helpful. Just wondering—does the 2021 Camry XSE have an AUX jack for audio?
No AUX jack in modern cars anymore. Everything is Bluetooth or USB now. You could use a USB dongle with an AUX jack or just connect via USB.
Thanks! If I use a USB cable, does it matter which port on the dash I plug into? And if my car already has Bluetooth, is there any real reason to use USB for audio?
@Porter
Any USB port that supports data should work. If it’s just for charging, it won’t transmit audio. Bluetooth is more convenient, but USB might give you better sound quality.
Vinn said:
@Porter
Got it. I already use a USB cable to connect my phone for Android Auto, but can I connect both my phone and a tablet at the same time? If I can, will the tablet’s audio play through the car speakers? Also, do I need a special USB-C cable, or will any one work as long as it supports data?
