I’m planning to replace the spark plugs on my 2019 Subaru Forester. I’ve heard I might need a wobble extension and a special spark plug socket, but I’m not sure if that’s all. Any advice or tips would be appreciated!
Koken Tools is currently running a black friday sale, and they make my favorite tools for this job.
First, you’ll need a 14mm spark plug socket – I’m very fond of 3300CZ-14
Second, yes you’re going to want a couple of wobbly extensions to make life easier, and again Koken has excellent offerings. You can get the full set if you want, but the 50mm and 75mm are the two lengths I use for spark plugs.
For a ratchet, you do want something with a relatively thin head – I invested in the Matco frankenratchet from MrSubaru but really any 3/8 drive ratchet with a flex head and some length to the handle would do. I used the classic Gearwrench 90T for a long time beforehand, and I still use a Tekton as my go-to hand ratchet these days. When doing spark plugs, I’m really only using the ratchet to break loose (and to final torque tighten) the plugs; the knurling on those koken extensions makes it easy to just spin the plugs out by hand once loosened.
There are a couple other things you’re going to need:
You’ll want a standard-depth 10mm socket for the ignition coil bolts. (You don’t need to disconnect the electrical connectors from the coils, the boots will flex I promise, just push them out of the way toward the rear of the car)
You’ll need a way to remove the battery, which probably means you’ll need a 10mm wrench of some flavor and a deep 10mm socket for the nuts on the tie-down rods
On the passenger side, life is going to be a lot easier if you remove the air filter housing. You’ll need an 8mm something to remove the band clamp (personally I prefer a nut driver so you don’t over-torque it on install) as well as the same long extension setup you used on the battery cable bracket in step 3.
Haven’t done them on a forester, but on my old wrx and 12 Legacy, access is limited, particularly on the drivers side. I found that in addition to the spark plug socket (I like them to protect the insulator) I used small extensions I could put in one after the other to get the length I needed helped - I don’t usually use a wobble for that. Looks like a similar issue for my current car (24 Legacy)
Macon said: @Indy
Your '24 will be a bit more challenging than both your EJ-powered previous cars
Ugh. I was thinking it looks about the same as my old 12 LGT - does the giant harness on the side of the engine not move or something? I was sort of hoping it was just pull the battery, shift the harness and proceed as with the old car… (current car has the FA24)
Bare minimum I use a 3" wobble extension with a 14mm spark plug socket. You can use a regular socket also, just be careful cause you can damage the plug if done improperly. Also need a short 10mm socket for the coils. You might want to remove the battery for more space on the driver side, so a long 10mm socket for that. And you’ll need to remove half the airbox for the passenger side, so a flathead screwdriver for the hose clamp.
1/4" drive 10mm ratchet with short socket to get the coils out of the way.
I use a 14mm spark plug socket with 1" extension and a swivel joint. (all 3/8 drive) sometimes moving the air cleaner housing and battery out of the way will help.
