2017 Toyota Corolla LE Software Upgrade!
Just bought a '17 Corolla, and the multimedia system doesn’t have Entune or navigation. Looking for a way to upgrade/flash a system onto it (Toyota software or Android, since I don’t have Apple) to bring it out of the dark ages. Any suggestions?
My 2014 Corolla is stuck in the dark ages too. I just use a phone mount and call it a day.
Yeah, I’ve been using a phone mount too, but I’d prefer an actual head unit upgrade.
Check if your head unit supports a firmware update. Some '17 models can be updated to add Entune, but it depends on your system version.
How do I check that? Through the settings?
@Kasey
Yeah, go to ‘Setup’ > ‘Software Update’ on your system. If you have an update option, Toyota might still have an official one available.
lorenza said:
@Kasey
Got it, I’ll check that out. Thanks!
Honestly, you’re better off replacing the head unit with an aftermarket Android Auto one. Plenty of plug-and-play options for the 11th gen Corolla.
Any recommendations?
Check out the ATOTO A6 Pro or Sony XAV-AX5500. Both have solid Android Auto support and won’t break the bank.
@Grey
Looks good, I’ll look into those. Thanks for the info!
If you want to keep it OEM, you could try sourcing a higher-trim Toyota head unit from a junkyard or eBay and swapping it in.
That’s a solid idea, but would it need extra wiring?
@Kasey
Depends on the trim level. If you get one from a similar model year with Entune, it should be mostly plug-and-play, but navigation models might need extra wiring.
Barbara said:
@Kasey
Good to know! I’ll research which models are compatible.
