We have a 2024 hybrid and the wife wants front and rear dash cams like in our Subaru. I have the front sorted, but I’m not sure how to power the rear cam. The Subaru has a rear cigarette that made power easy. I’m lost for the Highlander. Any recommendations for power for the rear?
BTW I don’t want to hack up wires. I prefer a plug and play option, if possible.
@Dara
The best approach is to buy a dual camera. It’s powered at the front, with a processor/camera mounted on the front windshield, and another camera at the back with a cable routed between.
There are plenty of cheaper knockoffs on Amazon, but I like Blackvue models from eg blackboxmycar.
Lighter plug-ins are convenient, but man I hate wires dangling all over the place.
Yeah, it’s weird that they don’t have a 12v in the rear part. I avoid running wires close to the airbags. For my Viofo A119, I run the cable from the middle console under the floor mats to the side and up. I added a few 3M velcro to manage the cable. For the front camera, I use this dongar to get power from the mirror. Very happy with the setup.
My rear cam uses a USB cable. I use the 2nd row USB port and run the cable under the floor mats and along the trim on the bottom to the back. Then up the pillar to the top center, where my cam is mounted.
But on the 2024, it looks like the wiring already goes through the bottom, outside to a covered connector for trailer wiring. On a 2019, a hole has to be drilled to the outside. Either way, there are power wires back there, but I don’t know if they just go to the lights, or if there is a wire that is always hot.
If you are going to power it from the front (is there another way?) then forget the fuse box solution. Go to the Dongar website and get an adapter that is hidden and runs off of your powered rearview mirror. I did this and it is a life changer.
Please forgive my naiveté–but why can’t you just run & hide the cable along the headliner to the rear glass/hatch area, as I did with my 2013 Highlander? My Redtiger Front & Rear cams came with extra-long USB cables. In any case, best of luck!
