4 Runner routine maintenance
I have a 2014 Runner with 52,000 miles and have been keeping up with regular oil changes. I recently had a recall for a software update, and the dealer recommended a lot of additional services, which I chose to decline. Is there any other maintenance I should be considering at this point? Thanks.
Many of these tasks can be done yourself. At that mileage, I’d suggest changing the transmission fluid and rear differential fluid. If you have 4WD, you should also change the transfer case and front differential fluids. I’d recommend avoiding the dealer for these services as they usually charge 150-200% more than other certified mechanics. Best of luck and enjoy your Runner!
I guess I made a typo, it is actually a 2021 4Runner. Thanks for the input!
Doesn’t matter, the maintenance schedule is the same as I mentioned earlier. I highly recommend sticking to the OEM schedule.
