Can anybody help me find where the hell the indicator relay is? My indicators aren’t working, and I’m not sure where to look for the relay. Any advice would be appreciated.
I think the relay is usually located under the dash, near the steering column. Have you checked there yet?
If it’s not there, sometimes it can be in the fuse box. Make sure to check the manual for the exact location.
I had a similar issue before. It turned out to be a loose connection. Make sure all wires are secure.
If all else fails, you might want to consider taking it to a mechanic. They can usually diagnose electrical issues pretty quickly.
Look for a diagram online. Sometimes they can show exactly where the relays are located.
