Anyone else having trouble with their key fob?
My key fob stopped working the way it used to. Sometimes it doesn’t unlock the car at all unless I’m super close. Has anyone else had the same problem? What worked for you? I’m not sure if I should replace it or take it to a shop.
Yeah I had something similar happen last week. Mine only worked if I was standing right by the door. I swapped the battery and it worked like new again. Try that first maybe.
Same here. My fob got wet once and started acting weird. I opened it up and let it dry out and it was fine after that.
If you already tried a new battery and it’s still weird, there might be something messing with the signal. I’ve heard that parking near certain electronics can mess with it.
The person who posted this should try using the backup key fob if they have one. That helped me figure out the problem once. It turned out only one fob was bad.
Yeah same here. Mine just stopped talking to the car one day. I had to reprogram it. I found some easy steps online for my car and it worked after that.
Seems like this is happening to more people lately. Maybe the cold or something in the air messes with it. Hope yours works soon.
