Anyone know the torque specs for a 2015 Prius engine mount?
Hey all, I’m trying to find the engine mount torque specs for my 2015 Prius (1.8 hybrid). Anyone got a clue?
I think there’s a doc floating around that has all the specs. Did you try searching online?
Yeah, found a Dropbox link that kinda helped. Just hoping someone has a quick answer here too!
I got the same car! Found the specs through a Toyota service PDF once. If you need front and rear calipers, those might be separate docs.
Oh nice! Do you have the link to that PDF?
Let me check… I think it’s on Dropbox. Sometimes these files have separate front and rear specs.
I think the 1.8 specs are slightly different than the 1.5. Might wanna double-check that you’ve got the right one.
Good point! I got the 1.8 hybrid version. Thanks for the heads up!
FYI, if you go through a Toyota service tech, they sometimes give you links for stuff like brakes or mounts. They’ll ask for specifics, though.
Did you say links? Any luck getting them directly from the tech?
Yeah, they usually send a Dropbox link or similar, but you might need to ask for each part separately.
I use JustAnswer sometimes; the techs there usually have those PDFs handy. Might be worth a shot if you’re stuck.
Oh, never tried JustAnswer. Do they respond quickly?
Pretty fast, yeah. And you can request the same tech if you’ve worked with them before.
