Anyone using TRD pro wheels with 16s on a 23 offroad?
Not my photo… just wondering if anyone here runs this setup. I’m thinking of getting these wheels with either KO2s or KO3s on my 2023 Offroad. I think they originally came off a TRD Pro and that one might’ve had a lift from the factory. I’m trying to figure out if I’d need a lift too if I want to stick with 265/70R16 tires. Appreciate any help!
You don’t need a lift for 265/70R16. You’ll be fine without it.
No lift needed for that size at all. You can even bump it up to 265/75R16 and still be good without rubbing.
That’s exactly what I was wondering, thanks for the info!
Anytime man
@Donna
Just checked out your setup on your Tacoma… it looks amazing! I’ve wanted those TRD Pro wheels from the 4Runner too but I’m not sure I can afford a lift right now haha. Mind sharing your full setup?
@Finnley
Appreciate it bro!! You really don’t need a lift just for those wheels. It’s the tire size and wheel offset that makes more of a difference. Even a lift just helps a bit with rubbing, but doesn’t fix everything. If you’re sticking with the size I mentioned, you’ll be just fine. Tons of Tacoma folks use that size no problem. I’m running a 2” Bilstein 5100 lift, 1.5” Wheelers AAL in the back, 275/70/17 AT4s, and 1.25” spacers giving me a -27 offset on the Pro wheels.
@Donna
Seriously, thank you for sharing all that :heart:
Finnley said:
@Donna
No worries bro, enjoy the new setup when you get it!
Just a tip… for 16” wheels people usually run 75 series tires and for 17” they go with 70 series. Might help with picking the size.
Anyone here know the part number for these exact wheels?
I think it’s pt946-35200-02. That’s what I’ve found when looking them up.
Yeah it’s PT946-35200-02. These are 16x7 wheels with a +13mm offset.
Here’s a pic of how mine look:
I’ve got this exact setup with 265/75R16 BFGs. Kinda wish I’d gone with 255/85R16 instead for a little more height and a different look.
Just to add—lifts don’t always help with bigger tires. That size should be fine as-is though.
