Best brakes and rotors for 2022 camry xse
i have a 2022 camry xse and it’s almost time to change the brakes and rotors.
looking for recommendations on what to go with.
i was considering oem rotors since i’ve seen them recommended in other forums and pairing them with akebono pads, which would cost about $482.
it seemed odd to me that brembo pads are actually cheaper than akebono.
i also saw some people go with powerstop z17/z23 rotors and pads, and the z23 set comes in at $299.
anyone have experience with these or other recommendations? i live in a mountainous area, so i want something solid.
i’m using powerstop evolution pads. they wear well and don’t dust up my rims.
i also went with the drilled/slotted rotors from the same kit. they wear evenly and stop hard. there is a slight noise when stopping, but i had factory rotors warp on two camrys, so i needed a change.
my partner’s car has brembo rotors, and they’ve been great too. you can find the kits on carparts.com.
@CorollaCrew3
thanks, i appreciate the help. my factory rotors also squeaked and warped, so i was hesitant to go with another set.
is the noise from the powerstop rotors just a squeak?
also, is your partner’s car running brembo rotors and pads
@Kieran
brembo rotors on the front with evolution pads.
my car is quiet unless i hard brake, then there’s a low moaning sound as it grabs.
if you’re doing the rears, don’t forget to release the rear parking brake if you have the button. i use a toyota code reader for it:
amazon.com: 2025 launch creader elite v2.0 for toyota lexus bi-directional scan tool
or you can use the button sequence to release it—look it up, i think it’s up up up, then down down down and hold for 30 seconds. you’ll hear it whir when it’s done. then you’ll need to re-engage it after the job.
@CorollaCrew3
got it, thanks. first time doing brakes on this car, so i’m hoping videos will walk me through it.
