Best spacer size to get that flush look?
Hey all, I’m trying to get my truck wheels to sit flush with the fender. What size wheel spacers would you recommend to achieve that? Any brand suggestions would also be awesome.
I’ve used 1” spacers on my ride and it sits perfectly flush with the fender. If you’re looking for a bit of a poke, go with 1.25”. Spydertrax and Bora are solid brands to check out!
Nice! I’ve used titan spacers before but I’ll look into those brands. Thanks for the suggestion!
I’ve got 1.25” spacers with a leveling kit and 265x75x16 KO2’s. The look is just right for me :+1:.
I had 1.25” KSP spacers with TRD off-road wheels. The fit was basically flush. Now I’m running 0 offset wheels, which look almost the same.
Why not just get rims with a proper offset?
I’m thinking of keeping it simple for winter but yeah, wider wheels for the summer are in the plans!
Don’t forget to use Loctite on those spacers and torque them down properly. Re-check torque after rotating your tires too.
Hey, what seat covers are those in your truck?
They’re the Browning Duck Camo covers. They fit pretty snug.
Is that a Maui Sounds box with the 3 subs I see in the back?
Yep, it’s the one with 3 6.5” subs.
What’s the offset on your Pro Comp wheels? That should give you some decent stance, right?
Actually, I’m running all stock wheels right now.
