Brake controller for 2024 Tacoma?
Hello,
I have a 2024 Toyota Tacoma TRD Sport without the original brake controller.
Has anyone found an after-market solution? My truck doesn’t have a plug for a standard controller.
What did you install?
Hey there, fellow Tacoma TRD Sport owner! While Toyota doesn’t advertise it, good news – your truck is most likely pre-wired for an aftermarket trailer brake controller!
  • Look behind the driver’s kick panel for the harness.
  • Popular brands like Redarc or Tekonsha offer controllers with wiring kits.
  • Choose a controller compatible with your Tacoma’s year, model, and trailer weight.
  • If unsure about installation, trailer hitch shops can usually handle it.
hallo tales you can install this technology by applying this fully plug-and-play option that’s easy to install and simple to use. It mounts on your trailer and connects via Bluetooth to a handheld remote you can keep in your cab.
The 2024 does not have the harness
