I’ve had my 2024 RAV4 PHEV XSE for less than a year, and I’ve noticed the EV-only range went from about 40–42 miles when it was new to around 30 miles now. Is this normal? This is my first plug-in hybrid, so I don’t really know what to expect.
I’ve read that driving style and charging habits can impact the battery, but the range seems to have dropped faster than I thought it would. For example, when I’m below 10 miles of EV range and switch to sport mode, it goes into hybrid mode instead of staying in EV. I also don’t get the same “boost” feeling when I accelerate in power mode.
Here’s how I’ve been using the car:
I drive pretty aggressively and use a level 2 charger (48A) for scheduled overnight charging.
My weekday commute is 5–10 miles, so I charge every other day.
On weekends, I drive about 35–40 miles. I used to manage an entire day on one charge, but now I have to charge midday.
The dealership didn’t find anything wrong. They said I’d need to leave the car for two days for them to run more tests and send the results to Toyota, but they couldn’t guarantee a battery replacement, and I can’t be without my car for two days.
Has anyone else had this happen with a plug-in hybrid? Is it worth pushing for more testing?
The range adapts to your driving habits. If you’re hard on the gas, the car adjusts its estimate. Try driving gently for a couple of weeks and see if it gets better. Also, don’t forget to check your tire pressure.
Have you checked the vents that cool the battery? If they’re dirty or blocked, it could cause issues. Also, do you use the AC while driving? It helps keep the battery cool.
This car has a liquid-cooled battery, so the AC isn’t involved in cooling it.
How do I clean the vents? Do I just wipe them? I usually keep the AC on auto and set it between 65–70.
