How do I check the latest updates on my Toyota vehicle?
Does anyone know the best way to get the most recent status of my Toyota vehicle order?
If anyone is looking for updates, ask your dealer for the spec sheet link. Toyota no longer shows ETAs, but the spec sheet link still works for getting some details. Just make sure to get the updated link.
@Dayton
You can check the network tab for the new code instead of using the VIN to track the status.
Unclewaffl3s said:
@Dayton
Any idea how to get that new code? My dealer hasn’t been much help.
@Sunny
You’ll need to ask your salesperson for the dealer spec sheet link. That should have the code.
Unclewaffl3s said:
@Sunny
I asked my dealer, and they said only the inventory manager can access that link. They claim they don’t have it themselves.
@Sunny
That’s strange. You could also try using toyota-tracker.com if you already have the VIN.
Unclewaffl3s said:
@Sunny
I might call a different dealership and see if they can provide the link using my VIN.
Unclewaffl3s said:
@Sunny
I tried Toyota tracker with my VIN, but it didn’t work for me.
If the dealer category is G, your car is either already at the dealership or will be there soon.
Yes, G usually means it’s already at the dealership.
My earlier post got flagged, so I created a Google Doc with all the details instead. Hope it helps!
I got a VIN from the spec sheet my dealer sent me, but when I try to use it, the page says not found. This is for a 2022 XSE model.
I’ve been having the same issue. It doesn’t seem to work anymore.
I ordered a bz4x built in Japan on June 2, and it arrived at port on October 1. It’s still sitting there. Does anyone know what could cause such a delay, and how I can track it?
I tried entering my VIN, but nothing appears. Has anyone else experienced this?
Edit: Never mind, I figured it out. I had to refresh the page, and the info was right there.
Does your car already show as sold? The system only works for cars not yet sold.
@Mack
It’s marked as pre-sold but still available under inspection status.
Is $57,700 a reasonable price for an XSE trim with everything included?
Check what’s included in the price and compare it with other dealers. Ultimately, it depends on what you’re comfortable paying.
