How to Turn Off GPS Tracking on My Toyota Corolla?
Hello folks…
I have a Toyota Corolla and I’m trying to figure out how to turn off the GPS tracking feature of the car so that it doesn’t show up on the Toyota app. I’m aware that the app allows tracking of the vehicle’s location, but I’d prefer not to have this feature active. :wink:
You can turn off location tracking through the app settings. It is a bit tricky to find, but once you go into the app’s settings, you should see an option to disable vehicle location sharing.
Hi,
Check Toyota’s owner manual for specific instructions. Generally, disabling GPS services in your car’s settings or disconnecting the GPS antenna might help.
To turn off GPS tracking on your Toyota Corolla, access the vehicle’s settings through the infotainment system, navigate to location services, and disable the GPS tracking feature. Consult your owner’s manual for specific instructions.
Removing the sim card will help to prevent communication with their servers, while also not voiding your warranty (according to an article I read the other day).
Simply remove the wires to the antenna, another way to gain access to your car through the diagnosis tool, and check for settings to disable the Positioning device.
