I got my first Forester 6 months ago (2016, used). The AC stopped working right, so I brought it in today and was told the compressor, evaporator, and a few other parts need replacing. The quote? $2,200.
I’m thinking of checking with some local shops, but a friend once told me you should always stick with Subaru for service or you’ll regret it. No clue where he got that from, but now I’m unsure.
Pierce said:
Any good mechanic can handle a Subaru. They’re not that tricky. I do a lot of work on mine myself when I can.
Same here. I’ve got a 2015 Forester. Unless my guy can’t do it (like trans work or tire stuff), I stick with him. Only been to the stealership twice—once for a recall and once when my mechanic had already closed. They gave me a long list of things to fix and I’ve been going through them one by one with my regular mechanic
@oddah
I got one of those FIXD computer gadgets and it’s helped a lot. One thing I learned though—if you see a bunch of codes after a long drive, especially for transmission, check the fluid. Change it and clear the codes. Easy.
Trevor said:
If it’s just the AC, go with a local shop first. Way cheaper.
Had the same thing happen with my old Hyundai. Dealer wanted $1300 for an old car. My local guy fixed it for half. Planning to switch to a Subaru next year.
AC shops usually know more about AC than dealership techs. A lot of times the dealer just throws parts at the problem. AC techs usually fix what’s actually wrong.
Yep. I had an AC guy come check my 04 Forester. Dealer said replace the whole compressor. AC guy just changed some o-rings and recharged it. Good as new.
Subaru does require training for dealer techs though. Might explain the higher cost.
@Hutton
Those trainings usually just tell techs to replace whole systems. Like with CVT valve bodies—they replace the whole unit instead of just a solenoid. It’s more about covering their bases for warranty than fixing the actual problem.
@Hutton
Never heard of a company paying dealers to go to training. My industry (electronics/software) always had us cover our own training costs. Curious where you got that info from.
Caden said: @Hutton
Tech training is definitely a thing in the auto world. That’s how folks become master techs and stuff.
Caden said: @Hutton
My family member has done multiple Subaru trainings. The dealer got paid by Subaru to have someone attend.
My parking brake issue was totally missed by Subaru. They just replaced the brakes and called it good. Local shop figured out the real cause—drag from a stuck brake.
