What’s next You lift up the back left side and take off the back left wheel Then you dig through the dirt and take off the plastic cover over the metal fuel pipe Then you check how rusty the metal fuel pipe is If it doesn’t fall apart right away you can put the wheel back on and drive for a bit before the new one arrives I’ve done that and have the marks to prove it
Looks good
Wow The 3rd and 4th are awesome
That’s what I’m going for
That is really cool
share this on this forum for rugged cars if you haven’t yet
I think it needs just a little bit more to be right for that forum I’m going to add some extra lights and a roof rack or basket lol
Off-road tires
CorollaCrew3 said:
Off-road tires
I just need to figure out what size lol
CorollaCrew3 said:
Off-road tires
Someone on a forum says 195/75/14 are a good size of tires for a raised Yaris depends on how much you lifted it though
I might get this kit for my 07 Where did you get your front lights
@Alexander
Was it easy to connect or did you have to change the wires I can’t tell from the online listing
Tai said:
@Alexander
The light itself came already wired up and was mostly easy to connect The only things that weren’t were the ring of LED lights where you’d have to connect using quick connectors I think https://youtu.be/3e6bOoXGWi4?si=9EHX5WvFCWxVYj1e
Putting it back to the regular height
How did you make the car logo black
Just a quick 4 coats of a spray on coating lol I suggest taking the whole badge off and doing that It will be a lot harder if you leave it on the front of the car
Needs a big sun shield above the front window and a multi-wing setup with a wing under the back window and a huge flat one even with the roofline
