Non-adjustable, so I had to use washers under the top wheel hub bolts. My rear wheels have visible negative camber (bottom out). I adjusted the camber on my Honda Fit the same way. Has anyone else used washers for this? It took me a few hours to align the rear wheels. I bought washers from a hardware store, and one of them was perfect!
I’ve done the same on my Honda Fit! Used washers under the top wheel hub bolts to fix rear wheel camber. It took a few hours, but finding the perfect washer at the hardware store made it work. Anyone else tried this?
