My partner just got a used Yaris in a really cool color. The only issue is that the buttons on the remote key don’t work. She can still use the keyless entry, and the dealer mentioned that the car does receive the remote signal. But the dealer said they can’t fix it.
The previous owner mentioned that it stopped working after the battery died. That might help us figure it out
I’m thinking of visiting an electronics shop, but I wanted to check if anyone here knows what might be wrong
Try replacing the coin battery first. I had a similar issue and just changing the battery fixed it. If your fob is like mine, it just pops open and snaps back together.
Good point But the original poster mentioned both keys have the same problem
I will try this for both keys, maybe they are both dead
Keyless entry is a unique setup and doesn’t need a battery. The buttons use a coin battery, so you should change that. If that doesn’t work, the remote might need to be re-paired with the car.
Thanks for the info The problem is we already have two keys and neither of them work does that mean they need to be re-paired
You should also get a second key and get both of them programmed at the same time
