Seeking Advice - How do I use the 2023 RAV4 multi-information display?
Can someone explain how to set this up, please?
I have a 2023 Excel with a 12.3-inch digital dash display. When I press the < and > meter control buttons (the circular ones on the left side of the steering wheel), a small menu with options 1, 2, and 3 appears.
I know that holding the OK button lets you scroll left and right to check or uncheck boxes for what you want displayed on the left and right sides of the dash. However, I can’t figure out what selecting 1, 2, or 3 does. When I asked the dealer, they said that 1, 2, and 3 allow you to configure three different sets of items on the dash. If that’s true, I would expect to see different items checked or unchecked in the menus depending on whether 1, 2, or 3 is selected. I’ve spent a lot of time trying to figure this out, but I can’t see any difference.
I’ve read the relevant section of the Owner’s Handbook multiple times, and it’s not helpful.
I’m usually good at figuring out menus and digital systems, but this one has me stumped. Is it just me, or are others also having trouble with the 12.3-inch dash setup?
As a Toyota owner with a digital dash display, I initially faced similar confusion with customizing and saving different display configurations. After some trial and error, I realized that each preset needs to be individually configured.
Once I figured out that I had to actively change and save the settings for each preset number, it became easier. For instance, I set preset 1 for daily driving with essential info like speed and fuel efficiency, preset 2 for road trips with navigation and media info, and preset 3 for off-road adventures with compass and pitch/roll indicators. Understanding this process helped me utilize my digital dash display more effectively and tailor it to my needs.
navigating a new car’s infotainment system can be tricky!
The 2023 RAV4’s multi-information display (MID) offers many features, but fret not, I’ve been digging into resources to help you out. Here’s a rundown:
Types of RAV4 MIDs and Their Controls:
There are two main MID options in the 2023 RAV4, depending on your trim level:
4.2-inch MID: This base model MID is controlled by buttons on the steering wheel. The buttons allow you to cycle through menus, adjust settings, and select options.
12.3-inch MID (Higher Trim Levels): This larger touchscreen MID offers more features and is controlled by touch, similar to a smartphone. There might also be some redundant buttons on the steering wheel for frequently used functions.
General Navigation Tips:
Here are some general pointers for using your RAV4 MID, regardless of the size:
Steering Wheel Controls: Familiarize yourself with the steering wheel buttons. They typically control navigation, audio, and basic MID functions like trip computer and settings.
Home Screen: The MID will have a home screen that displays essential information like speed, fuel level, and time. You can usually customize what appears on the home screen.
Menus and Submenus: The MID uses menus and submenus to access different features. Use the buttons or touchscreen to navigate through them.
Owner’s Manual: Your owner’s manual is your best friend! It will have detailed instructions on using all the features of your specific MID, including button functions and menu options.
Here are some resources to help you get started:
Toyota RAV4 Owner’s Manual: This should be in your glove compartment. You can likely also find a digital version online.
YouTube Tutorials: Search for tutorials on “2023 RAV4 MID” or “2023 RAV4 Multi-Information Display.” There might be visual guides that can help you understand the layout and functionality.
Additional Tips:
Don’t Fiddle While You Drive: Always prioritize safety and avoid messing with the MID too much while driving. Get familiar with the controls beforehand or pull over to a safe spot if you need to adjust settings.
Explore Gradually: There are a lot of features on the MID, so take your time exploring them and customizing the display to your preferences.
By following these tips and utilizing the resources available, you’ll be a pro at using your 2023 RAV4’s multi-information display in no time
