Tires worn on outside
My 1993 Camry 5sfe has uneven tire wear on the outer edge of the passenger side tire. Could this be caused by a misalignment or worn suspension components like ball joints or lower control arms? Any ideas on how to diagnose the cause?
Yes, the uneven tire wear could be due to misalignment or worn suspension parts like ball joints or control arms. Check these components visually for wear or damage, and consider getting a professional alignment and suspension inspection to diagnose the issue accurately.
If the outer edges of the tire wears faster than the center, the tire is likely underinflated, says Popular Mechanics. Follow the tire pressure recommendation on the side of the tire and add air to the tire as needed.
Uneven outer tire wear on your 1993 Camry could be due to two main reasons:
  • Misalignment: Wheels aren’t angled correctly, causing them to rub the road at an uneven angle and wear down the outer edges of your tires.
  • Worn suspension components: Worn ball joints or lower control arms can allow your wheels to move out of alignment, again leading to outer tire wear.
Hi Lexus. Uneven tire wear on the outer edge of a tire can indeed be caused by misalignment or worn suspension components such as ball joints or lower control arms. It could also be due to an out-of-balance tire. You should probably Inspect the suspension components for any signs of wear or damage.
