Toyota hilux gd6 2024 model c1203
Showing abs light and swerving sign
Hello, a pic of the errors in the dash if you don’t mind
The problem could be caused by a bad wheel bearing, a faulty wheel speed sensor, the ABS pump, the ABS control module, damaged wiring, or an issue with the steering or yaw sensor. To know for sure, you’ll need to scan the ABS system for error codes. Otherwise, it is just guessing and until diagnosed and repaired, the lights will stay on
