What’s the difference between the Prius Prime XSE Premium and Prius Limited AWD?
Which one is better?
The main difference is that the Prime is a plug-in hybrid EV (PHEV), while the regular Prius is a standard hybrid (HEV).
Just in case that’s not clear enough:
  • BEV (Battery Electric Vehicle): Fully electric, no gas engine, only works when charged (not relevant here).
  • PHEV (Plug-In Hybrid Electric Vehicle): Has a gas engine and a larger battery that you can plug in. Great if you can charge it daily, especially if your commute is under 40 miles. This is the Prius Prime.
  • HEV (Hybrid Electric Vehicle): No need to plug in. Runs like a regular gas car but with a battery assist to improve fuel efficiency. This is the regular Prius.
  • ICE (Internal Combustion Engine Vehicle): Only has a gas engine (not relevant here).
The Prime is a plug-in hybrid, which means it can run on pure electric power for about 44 miles before using any gas. The regular Prius is a traditional hybrid that uses both the engine and battery simultaneously without needing to be plugged in.
Here’s a more detailed comparison:
  • AWD vs. FWD: The regular Prius Limited has an eAWD option, with a rear electric motor that helps at low speeds. The Prime only comes with FWD.
  • Power: The Prime has about 25 more horsepower than the standard Prius, making it a bit more powerful.
  • Wheels: The Prime XSE Premium has sportier 19" alloy wheels, while the Prius Limited has a different design but still stylish wheels.
  • Interior: Both models have heated and ventilated seats, a 12.3" multimedia screen, and a power liftgate. But the Prime XSE Premium features sporty red seat trim, while the Prius Limited sticks with black or gray.
  • Glass Roof: Both have a fixed glass roof, but the Prime offers an optional solar roof that can help charge the battery.
  • Price: The Prime is more expensive, mainly due to its larger battery and plug-in capabilities. But it could save you on fuel if you’re able to charge it regularly.
