What's the lifespan of KO2 tires
Same exact tires, same size that came with my truck. I got 85 out of them. Looks like the second set will do the same.
Such a great tire. I use them on my 2014 Tundra too.
In Jesse Ventura’s voice: I don’t believe you. My Costco tire guys are shocked at 82,000 miles on a set of Michelin defenders. I just can’t believe you got that sort of mileage out of those tires. I rarely see a set make it past 60k. You need to share more info than just that you rotate with every oil change. What’s the PSI you’re using? How often do you check? What’s the average weight in your vehicle and what type of driving do you do? If I were you, I would reach out to BF Goodrich. You might get a free set.
Wow, are these load range E or C versions?
I got 60k miles on my KO2s. I’m replacing them next week with the KO3s because I tow and noticed some loss of traction this winter.
I bought a set of 315/75 R16 KO2 in October 2015. I finally had a blowout in December 2024 after 63k miles on my ’94 Land Cruiser. I never got a single flat until the blowout. I could probably count on one hand how many times I rotated them because I lifted it and drove without caster correction for some years. Yeah, I know it was bad. I replaced them all with KO3 and got an alignment the day after installation.
They still got life in them, get going! It’s impressive you got 100k on those.
I got that mileage or more on my Venom Power Terra Hunter X/Ts. For a lesser brand, I’m shocked they’ve lasted this long.
I have the same tires with 11k miles. Fingers crossed mine lasts as long.
Nice. Maybe you can last until the KO3s release this year.
Didn’t they come out about 6 months ago?
Sure, maybe the KO2s will be cheaper then.
Why are we getting downvoted?
