Where can I get a battery for my 2021 Corolla LE?
Got my battery tested, and it turns out it’s bad. I was told that this battery is a special type that can’t be bought just anywhere. Besides the dealership, does Walmart or any other store carry this battery? I need one ASAP.
Any place that sells car batteries should have what you need. Try a department store like Walmart, an auto parts store like AutoZone, or even online retailers like Amazon or Rock Auto.
Check the battery itself for the ‘group size.’ If it’s hard to find an exact match, most 12V car batteries will run your electronics. Just make sure the cold cranking amps (CCA) are equal to or greater than your original battery to ensure the car starts. Also, stick with the same type of battery, like lead-acid, and make sure it fits your battery tray and hold-down clamp.
The dealership is probably just saying that so you buy from them. Check Walmart and AutoZone.
Thank you, I will check Walmart.
