Why does my car make a squeaking noise when the heat is on?
Hey everyone, I have a 2023 Toyota Camry, and I’ve noticed a squeaking noise when I turn the heat on. Has anyone else had this happen? The car only has 21,000 miles on it, so I’m not sure if this is normal. I’ll probably mention it the next time I take it in for service, but I wanted to see if anyone here had any ideas.
Could be the blower motor bearings wearing out. Have you tried running the fan at different speeds to see if it changes?
Does the noise sound like a high-pitched whirring, or is it more of a chirping sound? I had a similar issue, and it turned out to be a belt problem.
I’ll check back in a week to see if there’s an update.
Hey, just following up—any updates on the noise? Did you take it in for service yet?
