Your truck already has a lift.
Yeah, but I’m not sure if it’s enough for 35s.
You should be fine… and by the way, nice truck!
What’s the exact lift on it?
@Kieran
Thanks, man! Wish it came with 35s from the factory… 33s just look too small.
Lloyd said:
@Kieran
If you ever want to get rid of those 33s, I’ll gladly take them off your hands! But seriously, I’m looking at getting TRD wheels with 33s soon. Your truck looks awesome! I’ve got a white one too, but just an SR5. Love these trucks.
@Leighton
Appreciate it! I’ll let you know what I end up doing with the tires. Just trying to figure out if 35s will fit properly. I like the factory wheels, but I feel like the truck needs taller tires.
@Kieran
Looks like a 1-inch level to me.
Some 35s fit, but KO2s won’t. I tried, and they’re too wide.
How wide are KO2s? I was told 12.5” should work.
Whoever told you that was wrong. I test-fitted them, and they rubbed badly, even before full lock. On a stock TRD Pro, you’ll need a lift or different wheels/offset to fit 35 KO2s. Mine is a 2024 TRD Pro.
No, you don’t need a lift.
No rubbing at all? Can I keep the factory mud flaps on?
My truck came with 35s from the dealer.
Did they add an aftermarket lift, or is it just the factory setup?
It has factory Bilstein 5100s, but 35s still fit fine on stock suspension as long as you don’t go too wide or change the offset with new wheels or spacers.
@Kelley
I just want taller tires, not wider ones. The stock width should work fine. Thanks for the info!
If you’re planning to take it off-road, you’ll need a lift for 35s, or they’ll rub on rough trails. I do a lot of desert runs with my 2023 Pro, and it handles great on stock tires with no lift. The only change I made was switching to Wildpeak AT4s in the stock size.
I don’t plan on hardcore off-roading, but the 33s just look a little small to me. Appreciate the info!
Nice truck! Is it a 2025 model?
